Axles and differentials
RE: Axles and differentials
If you're already replacing them, might as well go with something stronger, like the 31 splines. As for brand, I can't really help you there, as I have no experience with any, but I would think the Moser ones would be fine.
Yea theres alot of money leaving my wallet if I decide to get 31 spline. What all would I need if I get 28 spline, or is it just a direct replacement? Also, do you all think 28 spline would work fine with just Drag Radials
ORIGINAL: svt_97cobra
I think im getting an eaton posi and 31 spline mosers within the next 2 weeks. My posi is gone; I cant spin 2 wheels coming out of the water box. It's way more than i'm going to use this summer, but it's going to be a track car as soon as i graduate in december. I figure if i'm going to spend any money on it... might as well do it right.
Its really not IF they will break ,,its more like When.....If your hookin with slicks,...sooner or later ....boom....and DR's maybe,,,,if its hookin,,,which I'm not...i've broken a fewaxles over the years...
ORIGINAL: code3GT
The 28's will be fine. I run 28 spline Moser's. You don't need to bump to 31's unless you are going with crazy HP. Even then, I would skip 31's and do 33's.
ORIGINAL: 8banger
I'd go 33 and cut the ends off,,weld on Big Ford ends,,....bolt in axles,no more c-clips....
ORIGINAL: code3GT
Wow, sounds like alot of work
