Saleen S/C on a 99GT?
I am in the market for a superchager and now im looking at a used Saleen s/c Series 2Roots Style with an innercooler. Is their anything I have to watch out for when installing this and should it fit ok? Do you think this saleen s/c would be better than a vortech or procharger? Any advice on this would be helpful.
RE: Saleen S/C on a 99GT?
ORIGINAL: DVS99GT
NO! The roots style blower is the least efficent of all. Alot of people upgrade their roots Cobra/Lightning blowers. That should tell you something. I would take a Vortech or a Procharger over a roots any day.
It comes with 30 lb injectors, heat exchanger, waterpump, throttle body, overflow tank, tubing, intake bolts, drive belt, pulley. how much boost does the roots style blower give u? Do you also think I should upgrade to 42lb fuel injector like jDaniel said? DO you also think it is better to wait for a used vortech to come along?
here's a pic
here's a pic
The roots isnt the greatest of blowers. What you really want is a Twin Screw or centrifugal blower. I know a guy here thats got a roots blower on his Saleen and he is upgrading it to a Kenne Bell. His runs 10 psi.
10 PSI Sounds good. Vortech gives u 8-9PSI . How much do you think that roots blower is worth? Im about to pay $1600 it has 5000 miles on it & comes with everything but the fuel pump. Is that too much to pay?
Thats pretty good but you do know you dont just throw a S/C on and go... dont you? There is more entail. Like a tune and if you put too much boost on the engine you could throw a rod br melt a piston. You might wanna look into it a little more.
ya but cant the GT engine support 10PSI b4 engine modifications are needed? I know u have to get it dyno tuned to get the timing and the air/fuel the right ratio but what else is required after installing the s/c?
