Need help with x pipe
I cant remeber which way my slp x pipe goes . Its just the "x" section. Which side does the shorter pipe that connects to the cat back go to, passenger or driver side?
If you're confused, Im talking about the two ball and socket connections after the "x" in the x pipe that connect to the cat back. One is shorter than the other. I have the motor pulled and entire exhaust removed. I need to know which side the shorter pipe goes on.
RE: Need help with x pipe
The shorter pipe on the header side of the xpipe is on the drivers side, and the longer on the passenger obviously.
EDIT: Duur my bad, just saw you ment connecting to the catback.... the shorter end if on the passenger side.
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
