headers
I just put the SLP longtubes on my 02, and I love them. They complimented my exhaust note very well, and gave a noticable increase in power. They were also very high quality and fit perfectly.
the best headers out there are made by hooker im not a 100% sure if they make em for these cars, which probably isnt helping but check wit them, they are a bit expensive. bbk makes good stuff for pretty cheap. lt's are better for everything, power and sound. good luck
Hooker does and the long tubes run about 550.00 for the basic set and 750.00 for ceramic coated or stainless steel. Long tubes are definitely better performance wise but may be more difficult to install as far as fitting them. I was going to get my stock manifold replaced with long tubes until I found out labor is about 8 hours or at least thats what I was told. At 80 and hour, that can cost more than the headers themselves. Check summitracing.com.
OK, I have to ask. Do you have a lift or access to one? I was told you need to lift the engine up. Not completely out, but enough to access the old manifold. Thats a lot of disconnects. Its either that or drop the K-member. Either way, its a big job I think. How long did it take you?
ORIGINAL: Shelbyville
what about mac long tubes...i also am in the market 4 headers..getting long tube...i was looking at mac...they are about 460...bbk is about 50 dollars more...slp are like 800...u gotta get ceramic headers which are a littkle bit more expensive..
