still some questions about shocks
ok im going for a good street car setup. want to squat as much as possible. anyways, what is more important and more significant. i am looking at strange 10 adjustables in the back. will these help that much or would front adjustable struts help more. i plan on getting some lower control arms in the rear very soon. little help educating me. i wanna plant the power as good as possible but still be able to take turns farely better than oem
thanks
thanks
RE: still some questions about shocks
You say street car setup but you want it to squat as much as possible. I'm guessing you're going to the drag strip every now and then?
If so, adjustables are the way to go. The only bad thing I've heard about strange is that they are noisy. Strange 10 ways or tokico illumina 5 ways are both pretty good.
I think you need both to really benefit alot, without the front struts you aren't going to have good enough weight transfer to really help you.
ya, i wanna go to the track about 1 or maybe 2 times a year. from what im getting from what you said, the struts are most important in the weight trasfer to lift the front end up. i can really only get one set at a time due to budget. should i go with the adjustable struts first then, in your opinion
treesloth
09-28-2015 07:03 AM
