High idle problem?? $50 to who ever solves it!
First off it's not the IAC valve!!!..lol I have a restrictor gasket in there and tried it both ways??? My car idles all day at 1,050rpms???never lower. When I'm driving and come to a stop and push the Clutch in (hint 5spd) the idle sticks at 1600rpms for 8sec. evrytime? I can set my stopwatch to it. Very annoying to pull up somewhere and your car sounds like your at the drag line! I get a computer code and it says Manufacturer controlled Vehicle speed sensor??? Is that the VSS on the tranny or is that possibly the IAT sensor? I tried a diff. Maf and didn't do a damn thing. I tried a new TPS an nothing. No vaccum leaks either.(only 85% sure on this one..sprayed carb cleaner and starter fluid all over made a mess)...I was determined..lol What the hell is my problem??? ANY help is much appreciated becuz I'm sratching my ***** on this one!..lol Paypal only for the money tranfer when I get the problem fixed!
RE: High idle problem?? $50 to who ever solves it!
From your sig it looks like you didnt do the u/d pulleys right? I was going to suggest the idle screw to, but that probably wasnt fukked with right? Of course it could have worked its way loose and opened up a bit.
After I did my pulleys, my idle would sit around 1200 rpms for about the same amount of time when i came to a stop. the rpms fluctuate a bit, but nothing as severe as what you are saying.
ORIGINAL: CHIC
Actually I have honed out the TPS screw holes to turn the TPS counterclockwise like 1/4" to get the rpms down that far. If I put the TPS where it belongs the idle surges up to 2100 and stays there all day!
ORIGINAL: red2k1gt
First off...there are no truths to the rumors that UDP's will affect your AC or your alternator. Did you recently have the battery disconnected?
