Wish to swap out my thermostat. Easy question. *Update*
Well I plan on flushing my cooling system today and I want to change the thermostat as well. I have an OR/H installed and I haven't ever had a tune or anything like that done to it. Just have the MIL Eliminators on it so I don't know what the pipe would be doing to my air/fuel ratio. Running Lean or Rich, I don't know. But I want to put a colder Tstat. Maybe a step down from stock spec. My question is would it affect my A/F ratio negatively in conjunction with the midpipe and also would I benefit power wise or acceleration response if I did this? Thanks for your replies.
Manny
02 Mustang GT
Manny
02 Mustang GT
RE: Wish to swap out my thermostat. Easy question.
No, your thermostat has absolutely no affect on how the engine runs other than it's temperature. It wont make your car any faster or slower, nor will it affect your A/F ratios.
Your fan is set to run at certain temps and when you changhe your T-stat it will not run insync with each other, but never the less I put a 180 in mine and haven't had any troubles, but I have a bit more than just exhaust!
ORIGINAL: AJ97GT
ORIGINAL: BuzzCut
Sorry but it does. It determines on when the computer goes into closed loop mode. Where do you people get this crap?
ORIGINAL: AJ97GT
Next time you're going to act attacking and say something like "Where do you people get this crap?", at least know what you're talking about.
Edit: While I was just now eating after posting this, I was thinking about it, and to give you the benefit of the doubt, perhaps you think that if he gets a cool enough thermostat that his car will never make it into closed loop mode. I'm not sure what the computer is exactly set to, but the temperature to go into closed loop mode is fairly low. Low enough that no thermostat you get will keep you too cool for it. And also, you'll actually hit closed loop in the same amount of time no matter what thermostat you have, so it would still have absolutely no affect.
Well I just got back from the shop from having my cooling system flushed and installing a 180 degree thermostat. Man it made a difference! The car feels like it does when I first start it in the morning. Really responsive and it feels like it has more zip to it. Even after it has reached "normal" operating temperature. Car just wants to go. Fans turn on with no problems and car seems to just drive better. Shop did it all for like $20 bucks. Not bad for some cheap maintenance.
ORIGINAL: SikGT
ORIGINAL: AJ97GT
Forgive me for saying this, but I honestly doubt anything you just said. The coolant flows throughout coolant passages in your engine. It never in any way affects the fuel or air or any other important systems, and therefore you car can't be affected, performance wise, by flushing out the coolant system. Hell, even if you were running it so hot it overheated, it wouldn't feel incredibly different until the entire engine blew up. Don't get me wrong, it's good maintenance to do. You need to keep good coolant in there so you don't have freezing or overheating issues, and if you don't flush, the internals can rust and corrode as well. $20 isn't a bad price I suppose assuming they did an actual flush of the system and that included the new antifreeze. It's common to put your foot down a little more after getting something done to your car causing you to think it might be better off, but flushing the coolant system can't restore any performance because it can't kill any performance either.
ORIGINAL: SikGT
ORIGINAL: AJ97GT
Uhh, sorry, no. As I said, all it affects is how fast your engine gets warm. Closed loop mode is based on a temperature, not based on what the thermostat tells the computer (the thermostat is purely mechanical on our cars and in no way connected to the computer so it wouldn't be possible). No matter what change you do to your thermostat, the thermostat itself will not affect the A/F ratio. Going into closed loop mode allows the computer to adjust the A/F based on parameters set in the computer.
ORIGINAL: BuzzCut
ORIGINAL: AJ97GT
The thermostat does not control the flow of the coolant, it simply diverts the flow to the radiator by opening at a predetermined temperature. The water pump speed affects the flow but does not control it.
