weight reduction
Old May 27, 2007 | 06:43 PM
alfonso1's Avatar
alfonso1
Default RE: weight reduction
damn thats alot of hp what u run in tha 1/2 or 1/4
Old May 27, 2007 | 06:44 PM
alfonso1's Avatar
alfonso1
i mean 1/4 or 1/8
Old May 27, 2007 | 06:48 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: alfonso1
i think you should just add power because weight dosint do a hole lot it helps but more power works better unless u r trying to save on gas
THAT IS HORRIBLE advice. Weight reduction is much more of a key than alot of power.
Old May 27, 2007 | 06:49 PM
code3GT's Avatar
code3GT
Mustang Nazi
What mods do ya have thathave gotten you to 440rwhp?
Old May 27, 2007 | 07:02 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: alfonso1
yep yep yep evan littel things to the engine helps more than weight and if you add power u will fill it and i ****in love that filling
PLEASE, please enlighten us on how you came up with this tid bit of information. Is it from experience or from what you have heard? For arguments sake, what do you drive, what is your power to weight ratio and what kind of times are ya putting down? I am anxiously awaiting your response.
This area is for Tech info and advice. If you are gonna talk out of your A$$, please spend more time reading, researching and learning...so your responses will be more educated rather then just taking up space. Okay? THANKS
Old May 27, 2007 | 07:19 PM
Frostbitten's Avatar
Frostbitten
15 inch aluminum wheels with15x3 upfront and 15x8 in the back. Makes a world of difference and feels like adding at least 30hp.....
Old May 27, 2007 | 10:54 PM
I G Joe's Avatar
I G Joe
ORIGINAL: thething313
thanks for the replies guys. I already am putting down 440whp and 470wtq, so i figured some different weight reduction things would help a little. One of the next steps for me is building the block, and i dont really have the money for that right now
get a tubular front end suspension. and convert to coilovers. a lightweight flywheel and aluminum driveshaft can help as well. there are tons of things you can do to reduce weight.
Old May 27, 2007 | 11:52 PM
01GT4.6's Avatar
01GT4.6
man there is some bad information in this thread. Yes HP is nice and so is a car that is lighter. But the one thing that noone has mentioned in all the crap in here is that one of the main benefits of lightweight parts such as wells, tires, etc is that is is not as hard on driveline parts. You are lesslikely to snap an axle if the wheels that the axles turn are light weight.
Old May 27, 2007 | 11:54 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: code3GT
wheels/tires
Old May 27, 2007 | 11:58 PM
01GT4.6's Avatar
01GT4.6
ORIGINAL: code3GT
ORIGINAL: code3GT
wheels/tires
