Installing 4.10 gears!!!
#21
RE: Installing 4.10 gears!!!
It really isn't that bad of a job if you take your time. Take a look at those instructions I posted earlier, and make sure you understand it all before you start. Then just set aside enough time to do it (2 days should be more than enough) and take your time. If you have the right tools, it is doable. When I did mine, I had never done it before either, and I didn't find it that hard. If you have some mechanical ability and aren't a complete moron, it will not be bad at all.
#22
For those of you saying don't do it you are wimps. Pay the money for someone to do it, why? The job is time consuming and requires some special tools but is within the realm of the average person with mechanical skills. Just do not rush it and be very meticulous in all you do.
Here are a few links
http://www.superstallions.com/tech/d...ars/gears.html
http://www.angelfire.com/theforce/5o...5ohtech001.htm
Good luck
Good luck
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
