obd code reader
Old May 29, 2007 | 09:52 PM
00blackstang's Avatar
00blackstang
Default obd code reader
if i erase my check engine like because i have an o/r mid pipe... will the check engine like still work as normal...... ( like if my car for sum reason started mis firing, would the light still go on? )
Old May 29, 2007 | 10:11 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: obd code reader
You need mils or a tuner to turn off your rear 02 sensors to keep the CEL off. If you just erase it, it will come back on. If you do it right, the CEL will work like it should for other codes.
Old May 29, 2007 | 10:26 PM
00blackstang
obd claims it erases it from the computer, doesnt just shuit it off.... so the cel should work normal for everything else?
Old May 29, 2007 | 10:30 PM
sprostang's Avatar
sprostang
I ♥ Acer
It will work for everything else but you still need to turn off the rear02`s.
If you don`t, it will come back on.
Old Jun 1, 2007 | 02:40 PM
96GTMustangCT's Avatar
96GTMustangCT
just get some mils or make them if you dont feel like spending money. i made a set and am about to install them. a guy on here said they worked for him and gave me the directions. goodluck
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
