Best way to clean out injectors?
RE: Best way to clean out injectors?
id never pour any kind of cleaner down the throttle body, if i want that clean, i take it off. i use the brake booster line and gas tank for seafoam, and ive only done it once because im not convinced it works and i wanted to see smoke (no smoke was seen)
ORIGINAL: 2002GTAUTOVERT
Well either take them apart and clean them, or have the injectors cleaned. At the shop I work at, we use a B&G cleaner that is in a canister that connects into you schrader valve, and uses compressed air to force that liquid in to the injectors.. Works really well.
