Remember that issue i had with the car jerking and stuff?
When id drive it more than 15 min straight, and id go more than 60% throttle, where it would jerk and **** like it was running outta power/gas/air/something? Let off the gas and it would spike to 5300 rpms, like it got a power boost, then it would shift and be ok again?
Well it stopped doin that for a week or so, but now it started up again. [:@] Only things i did different were put in 91 instead of 93 this past thursday, but the car started effing up yesterday. And when i started it last, i accidentally had the gas pressed a tiny bit (about an inch id say?). Im definitely thinkin its a fuel issue, but those two things were the only things i did differently, which coulda triggered the problem to come back.
Ideas? If its ****ty fuel again or something, or just sludge or something, im gonna run a cleaner, maybe seafoam then fill up on 93. I doubt hittin the gas when starting it would cause a problem, could it? [&:]
RE: Remember that issue i had with the car jerking and stuff?
jerking in the automatic's is very common when in 3rd and 4th gear and crusing at anywhere from about 30-70mph. i fixed mine when i built up my tranny. if you think its a fuel issue, id start with the fuel filter. if that doesnt fix it, id check the air filter and injectors.
ORIGINAL: 2002GTAUTOVERT
You said yours was the tranny, right? What exactly was the issue?
no tune, but it seemed to run a lot better on 93. At first, it took the car longer to mess up (20 min instead of 10), then in a week or so it disappeared completely. Fill up on 91 and 3 days later its actin up again. [:@]
lol the stock tranny wont commonly cause the problem you're describing. 4r70w's are known for sloppy shifts, driveline slack, and always being in the wrong gear.
ORIGINAL: ackuric
i personally would test the tps first, run a fuel stabilizer/cleaner, maybe clean the maf, and double check for any loose vacuum connections. after that i would start tuning up. its not throwing codes or flashing check engine lights so the ecu isnt detecting bad values at any sensor
ORIGINAL: GStam66
I took it to continental transmissions and they said it didnt feel like a tranny issue, they said it felt like it was starving for fuel. Also, mine will do it in any gear. It did it from a launch the one time, i was goin about 20 mph, in first...
