smoking engine
RE: smoking engine
75 psi i guess and o psi on cylinder 4?? sounds like you burnt a valve, lost a seal or your rings are gone. if its smoking i would try not to drive it. only way to be sure is to take off the cover and look at the heads, and check the bottom end for metal shavings in the oil. could be anything causing low/no compression, need more info.
RE: smoking engine
Are you sure you did the compression check correctly? What did all fo the other cyl say?
If those are really your numbers they it is time for a rebuild. With 0 compression in one cyl then your rings are gone and probably have broken ring lands. I wouldnt run the car anymore till you tear it down.
RE: smoking engine
ORIGINAL: mikewilkinson
hey guys,
have a 2001 cobra with a procharger. engine has been smoking for 100 miles. compression check showed 75 on 3 and 0 on 4. what could be the problem and how much am i looking at to fix it?
thanks
hey guys,
thanks
RE: smoking engine
this isn't my car, but i was looking at buying it. i've been looking for a supercharged car but can't afford the '03-'04 cobra's. should i avoid any supercharged stock 2 valves? thats what i'm interested in. what should i look for to be safe? low boost, or a completely set up dss block and forged internals? i don't know really what i'm looking for except a good priced supercharged mustang under $18k any suggestions?
RE: smoking engine
supercharged stock 2 valves, and any other superchaged vehicles are a much higher risk than any N/A vehicle, its common sense that since someone put F/I on a car, they did it to make it faster = harder driving = more worn parts in the engine and tranny.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
