Tuners, Programmers..
Im goingto be investing in a Tuner pretty soon but wanted to check out if they are really worth the money..I know one can do alot with a tuner but how much Hp and torque and mpg would the tuner make available to me, mods in my sig
-Mike[8D]
-Mike[8D]
Well unless you want to bump timing up or down... reset your speedo for a gear install or something of the sort I would recommend you get a dyno first and see if you are really in need of a tune. I went yesterday with a group of guys and had a dyno done and my A/F ratio was PERFECT all the way across the board. The guy told me that a tuner would probably hurt me in the end because its set up pretty well at this point. I was extremly happy.
ORIGINAL: jdaniel
you are running that chip from md though right? That would explain the a/f since that is what the chip does heh
Yes but mods will change the a/f some. He just happened to have the exact same mods as me lol! At any rate, chips / programmers are underrated - You get great power all accross the curve with a good tune, its like buying a speedcal, timing adjustor, a/f tune (that only a chip / tuner can give), calibrate shift points on a tranny, etc.
dude im telling you this i have a diablo predatoor hand held tuner and that mf-er help alot. now it wont up your horsepower. what i mean is i have 273 hp to the ground and with the predator i had 276. but low end power was incredible.im talkin a gain up to 18 hp in low rpms and also if you do anything internal just get a shop to throw in a perfomanc tune i say yes go for it well worth it money well spent
ORIGINAL: UT04GT
ORIGINAL: jdaniel
Yeap, thats right... but what im saying is that he is totally stock... so how far off could his tune be?
yeah im pretty stock, all i have is in my slp cat back K&N cold air and i just put on steeda pullies...i was gonn get the timing adjuster but found it to be really useless if i just got the tuner that actually does so mch more..and i do plan to get gears and such so i think the tuner would be a good stepping stone...somethign to consider now for the future mods..
-Mike[8D]
-Mike[8D]
ernesto-619
Sep 10, 2015 01:32 AM
