spuddering stang.
Old Jun 10, 2007 | 10:40 PM
96GTMustangCT's Avatar
96GTMustangCT
Default spuddering stang.
what would make my car spudder under load. when it is in my driveway at idle and i rev it a little its fine. but when im cruising around and get on it in the slightest it spudders bad. my buddy thinks injectors, or plugs and wires. seems like i lost a good amount of power since this has happened. also when this spuddering happens sometimes, i get a knocking sound under the right front of the car, i thought something with the suspension but it doesnt do it unless the car spudders. please help me out, im going crazy!!!
Thanks Everyone,
Zach
Old Jun 11, 2007 | 01:21 AM
1fast 99gt's Avatar
1fast 99gt
Default RE: spuddering stang.
mine does the same thing i would like to know to. Does it only happen when you when its at low rpms?
Old Jun 11, 2007 | 02:04 AM
jst854's Avatar
jst854
I would think the knocking sound is related to the engine/sputter. I also have a 96 gt and it recently started missing really bad, replaced the plugs and wires and that cleared it up. I would try that first.
Old Jun 11, 2007 | 05:18 AM
GT STANG's Avatar
GT STANG
the same happen to mine about a month ago just change ur plugs and it should clear ur problem right up
Old Jun 11, 2007 | 09:58 AM
96GTMustangCT
so it should run better/ restore the power that it seems to have lost. i just want it to run good ya know.. also yesterday i was driving home and on some new street they are paving one side said bump so i obviously slowed down, and the other side looked fine and said nothing, no f****** sign, so i slowed down right as i saw it, hit it kinda bad but i hope nothing is wrong. my alignment seems to be fine i just want to know how to check to make sure i didnt jack anything up. thanks
Old Jun 11, 2007 | 11:55 AM
exLT1to01GT's Avatar
exLT1to01GT
yeah I would try changing plugs/wires, probably should use some injector cleaner too and maybe change the fuel filter if it hasn't been changed in a long time
Old Jun 11, 2007 | 12:31 PM
Brute03's Avatar
Brute03
i'm thinking it's ignition related,puta fresh set of plugs and wires in and it should clear up
v8sn95
Sep 7, 2015 10:17 AM
Luke9222
Sep 4, 2015 06:46 AM
Moosetang
Jan 22, 2004 10:23 PM
szekas
Nov 12, 2003 10:43 PM
