not really sure
RE: not really sure
60,000:
Fuel filter, clean your air filter, check plugs (just change them), coolant flush, if you have an auto then a tranny flush with filter replaced (not sure of the manual's schedule), PCV valve change, check your brake pads, rotatetires, change oil and filter if you need to. That should do it.
RE: not really sure
I do mean spark plugs. I have an automatic and the most expensive part was the coolant and tranny flush. That was $303 at Ford. If you have a manual tranny it WILL be cheaper. The rest of this is not expensive and just requires a little time on your part if you can do it yourself. Plugs are around 2-3 dollars a piece, Fuel filter and PCVare below 20 dollars each.
