Just got my vortech...
RE: Just got my vortech...
ORIGINAL: White02GT
yea i bought a kit from jmschip.com and it came with eveything... I hope the snow performance is good because he said do that over an intercooler for the vortech...
im not saying it wont be ok, just disagreeing to the advice that a meth kit is "better" than an intercooler. Im saying the I/C is more reliable, thats why high HP cars use them over meth.....
I don't remeber if they say this in the instructions, but do NOT use a drillbit when installing the oil return line on the pan. you want to use a starter punch, and then a larger punch with the size yuo need marked on it, so that youbend the metal back and then acutally tap that.
Also, you will need some HEAVY grease to put on the tap so yuo don't put shavings in your oil pan.
the drain taps right into the very front of the pan, there is a small area that is flat right at the front.
The supply line hooks into the extra port by the oil pressure sensor.
