Dropping it!
Old Jun 14, 2007 | 10:25 PM
dye's Avatar
dye
Default Dropping it!
Im going to be ordering the H&R Super Sport springs soon. I was going to go with the Pro kit but i feel like its not enough for what im looking for. I have been looking at some old post and saw i will need CC plates, So i think i will be getting these http://www.americanmuscle.com/maximu...tes-94-04.htmlor the JM ones which are a little cheaper. With these will I be ok or is there anything else? Like shocks or sway bar.
Old Jun 14, 2007 | 11:13 PM
bigjohnson4.6gt's Avatar
bigjohnson4.6gt
Default RE: Dropping it!
MM is grade A stuff, you def need caster camber plates, and you dont have to do it right away but your going to eventually have to replace the shocks/struts cause its greater than a 1.5" drop
Old Jun 15, 2007 | 12:05 AM
hot wheels's Avatar
hot wheels
mm c/c plates are one of the best and you should buy some aftermarket shocks/struts. the tokico hd shocks/struts are great and inexpensive. lol and another benefit with tokico hd's are that they use the same blue as the supersport springs so everything matches.
Old Jun 15, 2007 | 02:16 AM
dye's Avatar
dye
Where is a good place to purchase the tokico shocks/struts?
Old Jun 15, 2007 | 03:20 AM
gt_stang101's Avatar
gt_stang101
ORIGINAL: dye
I suggest www.stangsuspension.com , I'd just get the springs and shocks and c/c plates from there if I were you.
Gene K
Oct 21, 2015 11:37 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
zanemoseley
Sep 6, 2015 12:58 PM
