pressure plate(help)
what happens when your pressure plate gos bad? i was out hot rodding and i think my pressure plate went bad,cable is good and the clutch fork moves when you push it in.i was able to drive the car home power shifting/with no clutch
so do i order the king cobra clutch kit?
(5 Speed Tremec Transmission
Brand New clutch(11 15/16), flywheel, and pressure
plate(not even 1000 miles on it) 6000-9000now
what he said when i bought it
(clutch now has a weird vibration in it)
RE: pressure plate(help)
[/align]
Duralast / Clutch Set-Matched
Warranty - LLT
NU31175
$119.99
Note:
Disc outside diameter 10 1/2", spline inside diameter 1 1/16", spline count 10, contains Premium friction, original equipment manufactured, clutch component kit includes: clutch, disc, release bearing, alignment tool, pilot bearing, spline lube.
anything wrong with this?
