HELP!! PICS INSIDE
Old Jun 20, 2007 | 06:02 AM
02GT87's Avatar
02GT87
Default HELP!! PICS INSIDE
alright guys so i got my oil change a couple days ago and the guy called me over into the work area i was already expecting something ****ty happened since it always does..anyways he brings me underneath the car and shows me some fluid above my mufflers it seems to be some type of oil but we couldnt pinpoint what it was i was in a rush and said i would bring it in later didnt seem like much of a threat but will you guys please help me figure out what this is!? maybe a gas line leak check out the pics for yourself
notice the stains on the mufflers
Old Jun 20, 2007 | 06:08 AM
POISND U's Avatar
POISND U
Default RE: HELP!! PICS INSIDE
Bad seal into diff leaking onto drive shaft yoke.
Old Jun 20, 2007 | 06:12 AM
02GT87's Avatar
02GT87
how much does a differential maintenance run me? would it be a gasket?
Old Jun 20, 2007 | 06:15 AM
lighswitch's Avatar
lighswitch
Oh wow I was going to do change the fluid in my diff, because it was leaking. but i have the same leak on my mufflers but no oil on the body, but mine has a leak from the muffler to the piping. anything serious?
Old Jun 20, 2007 | 06:44 AM
lighswitch's Avatar
lighswitch
Would changing my differential seal and fluid get rid of the problem Posind U
Old Jun 20, 2007 | 07:36 AM
POISND U's Avatar
POISND U
If that's case, of course. I'm just taking a guess based on the pattern of the spray. Have a rear end shop put the car in the air. They'll be able to tell you. If you don't already have them it would be a good time to have gears installed.
Old Jun 20, 2007 | 07:38 AM
lighswitch's Avatar
lighswitch
Im assuming I wouldnt be able to install a set a gears is that correct?
Old Jun 20, 2007 | 07:48 AM
POISND U's Avatar
POISND U
ORIGINAL: POISND U
Like I said, now would be a good time....
Old Jun 20, 2007 | 01:29 PM
lizzyfan's Avatar
lizzyfan
Underboss
Bad pinion seal
uberstang1
Dec 7, 2017 07:10 AM
PaulH2
20
Jan 31, 2016 09:48 AM
9550
Oct 26, 2015 05:01 PM
GLOCKer
Sep 28, 2015 07:36 AM
jaiidutch
Sep 14, 2015 10:29 AM
