What is the best motor oil for a 4.6L engine?
Old Jun 20, 2007 | 07:41 PM
clean97's Avatar
clean97
Default What is the best motor oil for a 4.6L engine?
Well my car is coming up on an oil change. I was wondering what brand of oil is best for this engine. I was guessing it would be Mobil One or Castrol Syntec. Would it be okay to switch to a semi synthetic or full syntheticif the original owners put non synthetic in it?
Old Jun 20, 2007 | 07:46 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
Default RE: Waht is the best motor oil for a 4.6L engine?
Mobil 1 5W20 Full Synthetic
Old Jun 20, 2007 | 08:03 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: 2002GTAUTOVERT
[sm=exactly.gif]
Old Jun 20, 2007 | 08:09 PM
lighswitch's Avatar
lighswitch
Royal Purple FTW!!! 5w20
Old Jun 20, 2007 | 08:23 PM
02 Ninja's Avatar
02 Ninja
Castrol Syntech, Mobil1, or Royal Purple will perform great if you want a synthetic.
Old Jun 20, 2007 | 08:29 PM
nyfreakinrican7's Avatar
nyfreakinrican7
I use the Motorcraft 10w-30 Synthetic blend it is only 2.32 a qt at Walmart. And I have 389,000 original miles on my car. I have only had to do the valve seals
Old Jun 20, 2007 | 08:49 PM
nanaki's Avatar
nanaki
Retired MF Moderator
use motorcraft synthetic 5w20. it's ford recommended and runs just dandy. it's also A LOT cheaper than mobile 1.
Old Jun 20, 2007 | 09:11 PM
NoRdO's Avatar
NoRdO
If you want to spend $ amsoil
Old Jun 20, 2007 | 10:16 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Amsoil is less expensive then dino oil. At $47 per year for oil and filter for Amsoil, plus whatever for the labor of actually changing the oil.
At any rate, the best oil is the one that you'll service properly. If you use cheap oil, you need to change it more frequently. If you use extended service oils, change as directed by the oil manufacturer.
Old Jun 20, 2007 | 10:34 PM
02 GT's Avatar
02 GT
i use Castrol
ocasionally i will use the royal purple
