BROKEN REAR SWAYBAR!?!?!
I duuno how this happend, but it did. Could it be the dip in my driveway??? When I pulled out, I heard a pop. Thought I just ran over something in the road. Kept hearing the rattling noise so I looked and didn't see anything, Crawled under and sure enough, the rear sway bar has snapped on the drivers side right where it bolts on. Cracked right around the bolt. The bolt is still on the car. Where an I get one of these? Do I need a "better than stock" replacement here? Do i need to leave it parked until I replace it? cause I have a 20 mile commute to school monday....??? Please help me out here guys! Thanx!
RE: BROKEN REAR SWAYBAR!?!?!
its most likely the sway bar mount/link, not the actual sway bay. You can get them at the auto part store, as long as its in stock. the kit comes with 8 bushings and bolts, ect. you will be ok with out it for now. might notice it around the turns. The car might sway a little bit more. no big deal though.
Thanx guys, so just yank it off until I replace it huh? Sounds good. Do you think a factory replacement will do the same thing? Or Should I go ahead and get a new/better one i.e. Steeda or Ford Racing???
ORIGINAL: Emann0007
