Put rear end on jackstands
I am getting a whine out back!
i am trying to figure out now if it's my gears or something else.
It sounds like mud tires on the road. What is that usually?
So i jacked the rear end up and it does it really bad around 50-60MPH range .... 4th not so bad but as soon as i got into 5 gear its really bad. it'ssomewhere outback.I only hear this whine when i am giving it gas. Not in neutral or when i let off the pedal....
axlebearings whine constant right?
i already bought gears pending money for labor but before i make the trip any suggestions. I cannot take car anywhere to get checked i work m-s 9-6
It's hard to tell if its the gears or the bearings without hearing it in person. But if your hearing it constantly and progressivly gets worse with speeds i would say its a bearing somewhere. now if it seems to happen onlyif youracceling or deceling or even just cruising at any speed i would say its the gears.
ORIGINAL: blackstallion666
From what you describe I would say its the Gears if it was a bearing it would be a constant noise
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
92 5.0stang
Aug 13, 2015 06:46 AM
