Professional Products?????
RE: Professional Products?????
ORIGINAL: BuzzCut
How do you know you have better power? The butt meter isn't accurate and is usually exaggerated. Let's see the dyno sheet.
ORIGINAL: OzzDOA
The throttle response is improved and there is a little more mid and top end power.
I have the PP 70 mm TB and plenum, they are the same as the Trick-Flow and will perform nearly as well as the Accufab--enough to be un-noticably different on an engine with OEM cams and heads.[/align][/align]Here's a link to Accufab's flow data (about 1/2 way down the page)--you can see the Trick-Flow numbers with both 70 and 75 mm TBs. There is also no reason to get a 75 mm TB on an otherwise stock engine, it will not flow any better and does reduce charge velocity at WOT; though not enough to really matter...[/align][/align][/align][/align]
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
