Professional Products?????
Hey everyone,
I want to get a 75mm throttle body and upper plenum for my 01. I want Accufab but they are over $400. bucks. I have seen advertisements for a company called Pofessional Products in one of my magazines I get. Has any one heard of them, or better yet have this unit? It is about half the price, but my dad always said you get what you pay for. Any help would be appreciated.
RE: Professional Products?????
Iwas wondering the same thing. I see the ad for the Professional Products plenum/TB all the time for about half the price. They sell them on Ebay. I don't see why they wouldn't do the same thing as all the other plenums. Their product looks like its great quaility but I'm like you dgantt, you get what you pay for...but sometimes you run across some really good deals .
I have it and it works well. The PP TB/Plenum is the same as the Trickflow ones. The throttle response is improved and there is a little more mid and top end power. Only problem I had with mind is the little cam at the end of the throttle cable didn't quite fit into the linkage correctly. I hit the cam with a bit of WD-40 and used channel lock pliers to get it in all the way. Other than that install was easy, took a total of maybe 40 minutes. Payed a total of $220 an some change.
All TB/Plenum combos are within 1-3 HP/Torque of eachother with a N/A setup. Only time you'll see a larger differance is with FI. And yes it comes in both satin and polished finishes.
ORIGINAL: OzzDOA
^ he's probably referring to the better throttle response.....while you cant really feel a difference in horsepower, throttle response is something that you can.....I did plenum/TB/UDP's at the same time and I definetly felt a pick-up in response.....
Location: Where gunshots are more common than birds chirping
ORIGINAL: GT03 TJS
