3in Exhaust
RE: 3in Exhaust
3" would give the car a really deep tone, but power would suffer. We run 3" pipes on most of our cars at work, but they are all 500+ RWHP, and most of them could use smaller pipe. 3" would sound sick, but you would probably run into clearance issues over the axle
RE: 3in Exhaust
If you go wit a HUGE supercharger and a NASTY 5.4, then yeah, but otherwise I would stay with a 2-1/2" manderel-bent system, because a custom 3" will most likely have kinks in it which would reduce the effective diameter to smaller than a 2-1/2" pipe
RE: 3in Exhaust
You really need around 600 rwhp before you step up to a 3" set up. With that big of pipes the exhaust cools to fast and slows the flow of it. When the flow slows all the gasses behind it start getting backed up which will cause backpressure and backpressure is bad.
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
