need injector knowledge
Does anyone know what size injectors i would need to run to get best performance from this setup? I have read how people stick with stock #19's and also jump all the way to #32's. Heres what i having done. Im keeping it N/A...
*10.5 : 1 forged pistons
*forged rods
*comp cams stage 2 xe270 cams
*beehive springs
*heads are port matched, ported and polished and 3 angle valve job
* LT headers, o/r h , LM2 catback
*Full bolt on's-75mm T/B and Plenum,UDP's, CAI ext...
* dyno tuned when done...........
my main concern is will my stock injectors be too small and if so will 24lb injectors be enough to achive all im going to be able to... and i may add a 100 shot later. any info would be great .And if anyone has a simular set up can u give me a idea of what kind of HP numbers i will be looking at to the wheels? Thanks!
*forged rods
*beehive springs
RE: need injector knowledge
thanks for the info... sorry to asksame old questionslike this, i know you all get them all the time but just wanna see what people think and know from their own exp. cause theres so many different responses. btw for those who care im making a write up / photo log of my progress so if any one here wants to keep it old school and just cam, port and bump the compression i will send you all what i had to go through and my info of my results so will have a good idea of what all this is gonna do for you if you plan the same route i do. so far im into my stock 01 gt cept for a cai about 3800$ for all parts paid for and engine assembley and machine work. heres a list of other things added from the the old one at the first post i made.
*total seal rings
*engine will be balanced
thats all for now will add anymore if it happens... ty for the responds!
*total seal rings
ORIGINAL: ninelives19821
thanks for the info... sorry to ask same old questions like this, i know you all get them all the time but just wanna see what people think and know from their own exp. cause theres so many different responses. btw for those who care im making a write up / photo log of my progress so if any one here wants to keep it old school and just cam, port and bump the compression i will send you all what i had to go through and my info of my results so will have a good idea of what all this is gonna do for you if you plan the same route i do. so far im into my stock 01 gt cept for a cai about 3800$ for all parts paid for and engine assembley and machine work. heres a list of other things added from the the old one at the first post i made.
*total seal rings
*total seal rings
You might get away with 19 lb/hrs, but with whats basically a forged shortblock you could make 320+ WHP.. which would be enough to warrent going with the 24s.
The simplest thing is to try it and see, if your tuner says your going lean and your duty cycle is to high, get the 24s.
Yourgoing tohave about the same setup that i do now but im on the stock shortblock and i made 310rwhp.U will proberly be close to 320rwhpmaybe a little more if its set up right.I run a 125 and a 150 shot on mine to and i have 30 pound injector's.I would go a little higher then not enough injector.Then uwont have to buy twice.I would go atleast 30#'s if your going to run nitrous.There not much higher then the 24#.My mods arein my sig
