Question for anyone who knows
RE: Question for anyone who knows
ORIGINAL: Lando10
i cant see that link you posted... it says that web access is restricted. does anybody else have any suggestions for fixing it??
alright thanks... is this anywhere near the gears because i might as well get some new ones if im messing around close to them. also SINISTER what size tire do you have on the front of you car?
ORIGINAL: Lando10
As for if it is anywhere near the gears, they are bolted together.
ORIGINAL: POISND U
The clutches in your Trac Lok unit are toast. They can't take that kind of abuse for long.....
Replace the fluid, and put syn in there with additive to see if it will fix it.
YES ^^^^ try that first. A while ago when my 2000 gt was in the shope my mechanic was explaining to me how if you dont have the addidtive in it will not work right. when you take a corner it allows one tire to move slower then the other if you dont have it in you will hear screeching from the tire that is on the inside of the turn. Cheapest way is to drain the fluid and fill her back up with the additive and see if it fixes it. Also when you drian the fluid lok for metal shavings or and differential gears worn out. You might find you problem.. hope this helped.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
