alright, well say I got these: VT stage 1 cams
Exactly what are all the effects of new cams, will I idle higher? Will I idle alot rougher? Will I lose gas milage?
I'm trying to figure out the benefits.
VT stage 1's are gonna give you around 25 rwhp and a nice idle. Piece of cake to do, you can use the AFM tool or drop the timing cover. Not for a first timer if your removing the timing cover because you've gotta set the cam timing back up, the engine is an interference seteup, meaning if not timed right your gonna bend valves.
After installing the cam with the timing set and the chains on with the crank pully, make sure the engine will turn over each cylinder making sure nothing hits
