Tire Size
Old Jan 20, 2005 | 05:48 PM
  #21
Blue70's Avatar
Blue70
Default RE: Tire Size
ORIGINAL: yoshis99_cobra
ORIGINAL: Blue70
Do yourself a favor and stick with the 315/35/17 They have the same diameter as your stock tires so you won't throw off your speedo, or odo, ect. They are plenty wide, I love them
FYI 335/35/17 are about .75" taller than stock/315's
Doesn't the Diabosport Predator Tuner check for that? I could have sworn I saw that when I was doing mine for the gear swap. I'll have to check it out tonight. I'll let you know unless someone else posts it here.
TruBlu03GT
Yes it does, but TruBlu03GT didn't say anything about owning a Diabosport Predator Tuner, so I was just giving him a heads up
Old Jan 20, 2005 | 05:52 PM
  #22
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: Blue70
ORIGINAL: code3GT
I just went and measured...The rears 335/35/17=25" tall with 13.5" foot print, the fronts 275/40/17's=24.25" tall with 10.5" foot print.
335 div by 25.4 = 13.19" wide.. so you are correct
You say 25" tall, but unless your tire is WAY over inflated, you have a flat spot on the bottom, and probably some tire wear.
I am running 22lbs.
Old Jan 20, 2005 | 06:06 PM
  #23
Blue70's Avatar
Blue70
ORIGINAL: code3GT
ORIGINAL: Blue70
ORIGINAL: code3GT
I am running 22lbs.
Ok so like I said, with a new properly inflated tire off the car, a 335/35/17 should be 26.232283 tall, or almost .75" taller than a stock tire. [&:]
Old Jan 20, 2005 | 07:00 PM
  #24
chriscindy6369's Avatar
chriscindy6369
Here's a set of tires that Look Good,
On my 94 i run the 315's till i remove my quad shocks then i'm running the 335's
[IMG]local://upfiles/6214/6E87AA8CB49441838DDC0D62F4D24F54.jpg[/IMG]
Old Jan 20, 2005 | 07:18 PM
  #25
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
so say i have a tuner is it cool to get a 335? or should i just get 315? what should i do cuz i want to get tires either this week or next week.
Old Jan 20, 2005 | 07:28 PM
  #26
code3GT's Avatar
code3GT
Mustang Nazi
Go with either. I just got tired of the 315's and wanted something a little wider.
Old Jan 20, 2005 | 08:02 PM
  #27
Blue70's Avatar
Blue70
Your car will look great with either...the choice is yours [sm=icon_cheers.gif]
Old Jan 20, 2005 | 11:07 PM
  #28
xtreme02gt's Avatar
xtreme02gt
Yep, it was my idea!!!!!!!! PUNK
Old Jan 29, 2005 | 06:36 PM
  #29
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
hey code3GT did you hafta do anything to make it fit or did they just fit in place? like will i have to remove anything underneath the car or anything like that or is it the same as getting 315's and just put them on your rim and then strap them on your car?
Old Jan 29, 2005 | 07:02 PM
  #30
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: DILO2001GT
I drove to the tire store, they took off my 315's, mounted the 335's and put them on the car, I drove away. And it's been nothing but looking "PIMP' ever since.
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
M3hunter
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
