HOW do you install Steeda MIL
i got my x-pipe on with the rest u see below but i cant figure out how to install the mil elimiators..
i called steeda tech and still can not fiqure it out....
i need a picture diagram or something
one of them fits the one side but the other does not fit, what i did was unconect the ones there and just connected the steeda one between them...
please help
please help
RE: HOW do you install Steeda MIL
no welding I don't think. I believe they just plug in, I didn't install mine had the shop do it. I believe they should just plug into your old plugs for your pre-existing O2 sensors. Should be easy to locate if you put the pipes on your car. I could crawl under mine and take a look for ya if nobody else knows for sure....
Yes I had to do the same thing because one end of the sensor did not line up with the ears...i took the MILs to work and grinded the ears off with our grinder then re notched where they needed to be. It will work fine because the clamp on top of the sensor will hold them in place.
Also, there is no reason your car should run any differantly..The only purpose for the MILs is to turn off your check engine light because of the X pipe. Should by no means effect performance.
thanks a lot for your help..... they are on now.......... i know you said it has nothing to do with performance but my idle is no longer bouncing up and down like a las vegas prostitute.
thanks
thanks
Your engine may have been idling abnormaly, due to the fact you had one MIL installed. The computer may have been reading this as a problem, since one engine bank appeared to be operating normally, and the other bank registered a problem.
