Oil filter not fitting right?
Old 07-22-2007, 02:27 PM
Hulk99
Hulk99's Avatar
Default Oil filter not fitting right?
Well I changed the oil in the 99 cobra for the first time today. SEVEN quarts of mobile 1 synthetic! Anyways when I went to take the oil filter off it was really fuggin tight, but I eventually got it off. Then I put the new one on... only problem is I hand tightened it then used a wrench and it will not sit flush against the block (in another words it doesn't thread on as much as the old one) I figured as tight as it was it had to be ok so I began adding oil and no leaks or dripping. Is this ok that it is not flush against the block? It is on really tight and
1. I'm sure its the right filter
2. I removed the old gasket
Thanks for any help.
Hulk99 is offline
Old 07-22-2007, 02:54 PM
chewie
chewie's Avatar
Default RE: Oil filter not fitting right?
Is the new filter/gasket in contact with its' mating surface? If it is, you're good to go. The edges of the filter will not be against the block.
chewie is offline
Old 07-22-2007, 02:59 PM
Hulk99
Hulk99's Avatar
ORIGINAL: chewie
Its really hard to tell there is not much clearance. I'm guessing it will leak if its not?
Hulk99 is offline
Old 07-22-2007, 03:05 PM
chewie
chewie's Avatar
When you were putting on the new filter....1st place some oil on your finger and smear it on the new filter gasket, then spin the new filter on until you feel contact (this being between the rubber filter gasket and the mounting surface you just wiped the old oil from).
Did you feel that initial contact of the rubber gasket and mounting surface? If so, you're good to go. The oil filter doesn't need to be on there "Hurcules tight". After the initial contact feel, follow the tightening instruction on the filter.
chewie is offline
Old 07-22-2007, 04:11 PM
blownbayou
blownbayou's Avatar
ORIGINAL: chewie
+1 on this
ALWAYS put some oil on your filter gasket BEFORE you appl the filter. I always turn mine HAND TIGHT (I am 6'5" 340lbs though) as much as I can go. Another thing to check is to see if the gasket came off the old filter and it is still attached to the mounting surface.
Later
blownbayou is offline
Old 07-22-2007, 04:51 PM
Hulk99
Hulk99's Avatar
Yeah the gasket definately came off the old one. And I always rub some new oil on the new gasket as well. It feels like it made contact with something, but it ain't easy to see like on the gt. Thanks for the advice guys, I guess I'll just watch the ground and see if I notice any oil. I've changed my oil in other vehicles about 1000x and never had anything weird like this fitment.
Hulk99 is offline
Old 07-22-2007, 05:58 PM
yourmom6990
yourmom6990's Avatar
ORIGINAL: Hulk99
never use a wrench to tighten it. always hand tighten it as much as you can.
yourmom6990 is offline
Old 07-23-2007, 12:51 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
ORIGINAL: blownbayou
ORIGINAL: chewie
+1 on this
Later
Everybody overtightens their oil filters. Never tighten it as much as you can go.
96GT226410 is offline
stangin1996gt
09-21-2015 11:01 AM
Demodulates
09-18-2015 11:14 AM
EASTIDEE123
09-15-2015 11:08 AM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Oil filter not fitting right?
