check out my plugs..
Old 07-22-2007, 11:27 PM
Quicktime_GT
Quicktime_GT's Avatar
Default check out my plugs..
I pulled the front passenger and front driver side plugs out of my car tonight just to see if they looked crazy or anything. I got some pics.. whats the greenish cast on the electrode about ? and how does the rest of it look?
tell me what you think...
Quicktime_GT is offline
Old 07-22-2007, 11:36 PM
ackuric
ackuric's Avatar
Default RE: check out my plugs..
is there any reason i dont see a gap in the first pic? greenish coloration would most likely indicate some sort of antifreeze leak getting on that plug, do you have the orginal plastic intake? any smell of coolant?
ackuric is offline
Old 07-22-2007, 11:45 PM
Quicktime_GT
ORIGINAL: ackuric
you can't see the gap in that pic but they were gapped fine... I'm just worried about the green color..
Old 07-23-2007, 12:58 AM
Stangforlife
Stangforlife's Avatar
What kind of plugs are they, copper? They look a little worn. Should've just replaced them while you had em out if there was any question of their condition.
Stangforlife is offline
Old 07-23-2007, 09:46 AM
Quicktime_GT
They are ngk TR6's. I'm not worried about the conidition of the plug, I put them in there right before I put the charger on, i'm just trying to make sure everything is running like its suppose to be.
Old 07-23-2007, 11:51 AM
svt_97cobra
I ♥ Acer
svt_97cobra's Avatar
I searched and found this.....
One sign of heat used by some professionals is electrode color. Many--but not all--spark-plug electrodes have an alloy composition that will oxidize green when subjected to high temperatures. This nickel oxide on the center wire and sidewire would show up first at the tip of the electrode--the hottest part--and progress from there, depending on temperature. Excessive green oxide may signal it's time to change to a colder plug. Several causes of high spark-plug temperature are described in the boxed information at left. The main thing to keep in mind here is that not all electrodes oxidize (turn green) at the same rate, if at all. Therefore, your best bet is to turn to a technician with experience reading plugs.
svt_97cobra is offline
Old 07-24-2007, 07:05 AM
contentsunderpressur
contentsunderpressur's Avatar
Have you had the car tuned on a dyno? Your running the right plug and the gap looks good but it looks like it's getting a little too hot in there. You look a little on the lean side to me.
contentsunderpressur is offline
Old 07-24-2007, 07:28 AM
Ryan86272
Ryan86272's Avatar
Hey, i dont know much about an F/I Application...but i have always heard(from ford Mechanics) and my friend who isnt a Ford Mech. That to ONLY use Motorcraft.... I just wanna make sure before im F/I
Ryan86272 is offline
Old 07-24-2007, 07:29 AM
undecided.steve
undecided.steve's Avatar
Not sure what your green stuff is but AFAIK Antifreeze turns white when subjected to heat so unless the stuff was dripping off the plugs, chances are good that it is NOT antifreeze.
undecided.steve is offline
Old 07-24-2007, 09:13 AM
ORIGINAL: Ryan86272
You can't use iridium or platinum plugs when you go FI. They burn too hot and will melt. NGK TR6s FTW!
Quick Reply: check out my plugs..
