torque converters?
torque converters?
what companies make aftermarket torque converters for the 4R70W? I looked on TCI and they want $1000+ for a stall that only goes 1500RPM more than stock, are all companies this expensive? And also why? Most torque converters are only a few hundred dollars and offerlike 2800 stall or 3200 and such.
RE: torque converters?
ORIGINAL: silverstang1996
Yep, Darrin is good at what he does.
You can also look into CircleD and DirtyDog converters.
The $600 figures are almost assuredly single-disc converters.....NOT recommended for use in our cars. Speak with Darrin or Alan (DirtyDog). They probably won't want to sell you a single-disc. The thinking here is that you only want to buy a converter once, and a single-discwon't hold upto higher hp demands. Protect yourself for future mods, and go with a multi-disc.
Also, you're going to want to be sure about your future plans. For instance, you don't want a 3800 stall if you're going to be putting a KB blower on it.
I like the stallthe carsoundsreal good and its alot quicker now, took ahit ongas,but I have Yokohama ES100's on
Stall speed is affected by hp. If you install a t/c that is designed to stall to 3600 in a 400 hp engine in a 300 hp engine, it's going to stall at a lower rpm.
Also, you pretty much have to mash it from idle to get a good idea of the true stall speed. Loading it up (brakes depressed) will not allow the converter to "flash", and you'll stall at a lower rpm. So, you need good traction to really get a feel for a high stall converter.
