New Intake Manifold
RE: New Intake Manifold
I agree with lizzy, just get a PI intake manifold. I picked up 35rwhp with mine and im running stock non pi cams/heads as well. Unless you want to spend $1000 + on a RR or P51 which is unneccessary, then look into the PI.
[/align]
I don't know what you are running but why would you want a metal intake manifold If you aren't going to be running boost or N20? A composite intake offers less heat transfer and improved performance because of it.
actually all most all the aftermarket intakes will work w/ an npi motor with an adapter kit
see below
[/align]
Track Heat® Intake Manifold for Ford 4.6L 2V
Add some ponies to your Mustang with Trick Flow’s newest high performance intake manifold—the Track Heat 4.6L 2V! Designed for hot street and track-ready 4.6L SOHC Mustang GTs, the Track Heat 4.6L 2V manifold improves performance in the meat of the engine’s powerband—between 1,500 to 6,500 rpm with unported cylinder heads and 1,500 to 7,200 rpm with aftermarket or ported cylinder heads.
The secret lies with the symmetrical high-velocity intake ports and 75mm throttle body inlet, which work together to substantially increase airflow and distribute it evenly to the cylinders. With this revolutionary intake, you will be rewarded with big increases in performance over more expensive manifolds! Plus, the intake’s A319 aluminum construction is not affected by nitrous like the weak, plastic factory manifold. And don’t worry about hood clearance—the Track Heat intake is a direct bolt-on replacement for stock and will fit under any stock-height hood.
[/align]
NOTE: Works with stock and aftermarket fuel rails. Will work on 1996-98 Ford 4.6L 2V with modifications
and here
http://www.texashotrods.com/StoreFro...mp;i=222304916[/align][/align][/align][/align][/align][/align][/align]
see below
[/align]
[/align]
and here
http://cgi.ebay.com/ebaymotors/NEW-9...QQcmdZViewItem
Check your local parts stores for the Dorman kit..They can be had here for about the same price..
http://cgi.ebay.com/ebaymotors/96-98-MUSTANG-4-6L-PI-Intake-Adapter-Kit-35RWHP_W0QQcmdZViewItemQQcategoryZ36474QQihZ020QQi temZ300082001589QQrdZ1QQsspagenameZWD1V
This one will bolt right up to everything right? If yes, im getting it right now
ORIGINAL: Brady98GT
