Timing Adjuster = fuel???
Old Jan 29, 2005 | 05:21 PM
Hells GT's Avatar
Hells GT
Default Timing Adjuster = fuel???
I am about to go put on my timing adjuster and I know it says anything above 10 degrees you MUST run 92 octane fuel..Right now I have a full tank of 89 oct and am wondering if it will be safe to run the 89 til it runs out? I plan on puting the timing to 13 degrees sound about right??
Old Jan 29, 2005 | 05:34 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: Timing Adjuster = fuel???
Go to Autozone and get some 104 octane boost and throw it on. Get the black bottle... not the red one. If not you might get some detonation. Why are you going 13 degrees advanced? If I were you I would go atleast 14 degrees advanced.
Old Jan 29, 2005 | 05:37 PM
Hells GT's Avatar
Hells GT
if 14 is safe to run ill run it...i just thought 13 was the max for safe running
Old Jan 29, 2005 | 05:39 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Nah, 14 is good. You may be able to run 15. You just have to do it and drive it to see if you have any power surges or if the CE light comes on. 14 is safe though. Thats what mine has been at for the past 5 months.
Old Jan 30, 2005 | 01:36 PM
ONE BAD GT's Avatar
ONE BAD GT
Why don't you just keep it at 10 and then when you get to empty fill it up with premium. Then take the 2 minutes to put it to 14.
Old Jan 30, 2005 | 02:01 PM
stonemonk9's Avatar
stonemonk9
Im guessin he just got it and wants to use it now and doesnt want to wait to go through the tank! I know thats how Id be. Also 14 is wat mine is set at and seems to work good.
Old Jan 30, 2005 | 02:19 PM
ONE BAD GT's Avatar
ONE BAD GT
Yeah i know but he wouldnt benefit from it unless he uses premium. I say go drive like a maniac for an hour or so and then fill it up with premium.
Old Jan 30, 2005 | 02:47 PM
UT04GT's Avatar
UT04GT
ORIGINAL: ONE BAD GT
I second that one, go scare the women and children [sm=badbadbad.gif]
Old Jan 30, 2005 | 04:04 PM
Hells GT's Avatar
Hells GT
Yea, I ended up installing it and leaving it at 10 until my tank runs down.
Old Jan 30, 2005 | 04:06 PM
Hells GT's Avatar
Hells GT
Does the timing adjuster set at 14 give the car more "getup" from the line...how does it actually work? If this is the case, how come you set a blown setup at like 8 or 9 degres.
