This leads me to another question . . .
RE: This leads me to another question . . .
depends on the cams.. say stage 2 cams and forged crank.. i could take mine to 6200-6500 i never took it that high though. if you want to spin that fast, also look into rods and pistons just to be safe
uhm, i think hes wanting to rev up to 7,000 rpm which would take a lot of work to be effecient in doing so.
you can rev to 6200 stock but your power drops severely after 5,500. with the aftermarket cams you can expect to continue making power up until 6,200-6,500, you may also experience some loss on the low end with that kinda setup.
you could probably spin up to 7,000 rpm with the right cams/valve springs and make good power doing so. code is the man to ask this question to, he has the highest revving 2v that i know about and makes power doing so
ORIGINAL: ben790450
The Patriot heads came with their own springs. Let me do some looking and see what they are. . .
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
