Super Charger Question
I will be installing a vortech V-2 SQ S-Trim SC on my 02 GT. I would like to know if anybody can tell me is there any problems with putting on and accufab TB and a C&L upper intake after the supercharger is installed. Also if anyone knows what strut tower brace will work with this SC could you please let me know.
THANKS
THANKS
There shouldnt be any problems with it at all. You wont be able to use the brace if you use the steel discharge pipe. The brace wont really work with any aftermarket pipe. Just the flex pipes.
i had the same problem with my 3 point brace an trying to put on the tunable induction TB pipe... i took off the brace and now im trying to figure out a way that i can modify it a bit anf still use it... im thinking of cutting off the 2 bars that connect to the firewall because that bar get sin the way... and just using it as a 2 point brace...
M3hunter
Sep 5, 2015 03:42 PM
