Oils that are good for the 4.6L
RE: Oils that are good for the 4.6L
I used Mobil 1 10w-30. My car only took 5.5 quarts.
Just to tell you for future reference, you can't tell if your oil needs changing by the color...Usually, the oil will turn brown within 3 hours driving timeof an oil change. Don't justify it by that, always go by date or by mileage.
Ohhh and please don't use FRAM filters...they are best for smaller engines.My car hada FRAM on it before I bought it, and my first oil change wassuch a PITA. I went to open the filter, and Ishredded the wall of the filter and got oil everywhere.I always use Motorcraft, because if Ford uses them for race Mustangs, they're good enough for me.
I asked my local Mustang shop and he said run 10w-30 because it runs cooler?
IDK...I just grabbed it because there werent 6qts of 5w-30 full synth. at Wal-Mart that day.
[quote]ORIGINAL: 35thAnni99GT
5w30 syntec w/ a FRAM ph2filter... then again I also work in Walmart Tire and Lube so all that stuff I get for free.
[/quote
Fram FTL! Wix FTW!
[/quote
Fram FTL! Wix FTW!
ORIGINAL: 96GT226410
I use 6 qtsof Motorcraft semi-synthetic 5W-20 oil with an FL 820-S Ford filter.
Later
Just my two cents. Follow this link to a good article on oil filter testing. Might
change your mind about Fram oil filters. It changed mine. I use nothing but Mobil 1
filters now.
http://minimopar.knizefamily.net/oil...html#fram-ph8a
filters now.
ORIGINAL: Shelbyville
filters now.
filters now.
FRAM's PH brand is the WORST filter to put on ANY car. The end caps are made of Cardboard (Possible collapse) and the check valve leaks dirty oil right back into your pan....These are just a couple of reasons why not to use FRAM. Wix and K&N are probably the best filters to use but, Motorcraft, Purolator, and NAPA GOLD (believe it or not) are some great filters at a great price.
Later
