best guages to get?
best guages to get?
hey guys, a friend of mine gave me his triple pod a pillar for my 03 gt auto. wanted to kno which should i get? not brand but more what type of guages are more vital to have. i kno air fuel ratio should b one of them, but what do u guys suggest for the other 2?
RE: best guages to get?
Definitely an oil pressure gauge, Id consider that the #1 priority. The stock "indicator" is a piece of ****. Then probably an air/fuel ratiogauge. The rest would depend on your mods. If you're fi boost andfuel pressure would be good ideas to go along with the oil pressure and air/fuel. If you're mostly stock a water temp would be a good idea to fill in the third pod after the oil pressure and air/fuel.
Unless you plan on getting a wideband air fuel gauge (expensive [for a gauge]), don't waste your money. They are pointless, and you only need a wideband if you have really extensive mods or boost. If you have no boost or nitrous, definitely go with a water temperature andoil pressure. The third would be your choice. You could get volts, transmission temperature, oil temperature, vacuum, etc.
If you had boost,the best would beboost, fuel pressure, and a wideband a/f.
thanx guys, i guess i'll leave the air fuel ratio and boost guage for later on, cus i do plan on gettin a kenne bell s/c in a few years. so for now i'll stick wit water temp. oil pressure and maybe volts.
ORIGINAL: BigRed03GT
