NEED HELP!!! Throw out Bearing??
Old Aug 14, 2007 | 05:18 PM
Jeffrey3085's Avatar
Jeffrey3085
Default NEED HELP!!! Throw out Bearing??
99 Gt 4.6 5 Speed... In the morning or when the vehicles cold i push in the clutch and i hear a grinding noise almost similar to that of the machine turning rotors ( resurfacing them ) but the only thing is the noise in the clutch stops when the car warms up a bit???? i had another mustang and it needed a throw out bearing and it would chirp when u let off the clutch.. this is the total oppisite it only makes the sound when i push in the clutch and its a total different sound this is a grinding sandpaper sound.. what baffels me is y does it only do it when its cold??????? clutch pushes in as normal and shifts like normal... pls help!!
Old Aug 14, 2007 | 05:21 PM
nathansee3's Avatar
nathansee3
Default RE: NEED HELP!!! Throw out Bearing??
Mine is in the same boat. I'm replacing clutch, flywheel, TOB, and pilot bearing.I let you know how it turns out. . . . Not doin it till this weekend tho.
Old Aug 14, 2007 | 06:35 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: Jeffrey3085
cant explain why it only happens when its cold but your problem sounds like the pilot bearing.
mrtrodonet
Sep 19, 2020 03:12 PM
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
Drastang
Sep 30, 2015 03:48 AM
Offendant
Sep 23, 2015 07:21 PM
