Shifting hard in the cold?
Anybody have a problem shifting when it's cold out? It's usually when i go into 3rd. It goes in hard and sounds like it's grinding but it's not. It'd pretty rough though. This a common thing or what? My buddy told me to just get a new shifter anyway so that's what i'm gonna do. Just wanted to know if anyone else has that problem.
RE: Shifting hard in the cold?
my car does that bit. i have a tri ax. if it just does it when its cold, and not a big problem i woldn't worry bout it. even if it is something you can fix, like a flywheel or pilot bearing, it's not bad enough to be worth the trouble of fixing.
Common problem on the 3650.
I had the TSB done for the 1-2 grind and the occasional 3rd lock out. Didn't really drive the car after it was fixed not sure if it was any better.
But I installed a MGW shifter in the car over the weekend. It is firm to shift, but it's positive and there is no hint of grinding even in the past two 15degree mornings I took the car to work.
Im not sure what will fix it but Ford did put out a TSB on most of the 3650 trannys from 01.5 to preseeent day to fix all the bad synchros if im not mistaken. I cant have it done because of the 4.10's. [&o]
