check engine light after pi cam/ intake swap
hey finished pi intake/cam swap. after starting it up i got a little smoke from back of pass valve cover, running rough, CEL w/ code P0300 "random/multiple cylinder misfire detected". no leaks, i checked all wires/plugs/ injectors/connectors, bla bla...all is good. i'm pretty sure i know what the problem is, just wanna hear it from somebody else.
RE: check engine light after pi cam/ intake swap
"The cause here would likely be something that upsets the engine's air/fuel mixture, such as a major vacuum leak, leaky EGR valve or unusually low fuel pressure (weak pump or faulty pressure regulator)."
