Clutch install writeup?
Old 08-20-2007, 06:25 PM
nathansee3
nathansee3's Avatar
Default Clutch install writeup?
Anyone know where to find a good clutch install writeup? Please post. Thanks
nathansee3 is offline
Old 08-20-2007, 07:24 PM
Mark99GT
Mark99GT's Avatar
Default RE: Clutch install writeup?
Are you planning on doing an install soon? I should be installing one in the next week or two,I could do a write up for you.
This should be of some use to you also
http://www.2kgt.com/item.php?itemid=105
Mark99GT is offline
Old 08-20-2007, 10:13 PM
nathansee3
nathansee3's Avatar
Thanks for that. Ya doin mine soon hopefully, just got the spec stage 3 clutch, spec billet alluminum flywheel, upr firewall adjuster kit" triple hook" and some FRPP pedals. Cant wait. thanks again
Old 08-20-2007, 11:14 PM
Shawn02GT
Shawn02GT's Avatar
Disconnect the negative battery terminal
Jack up the vehicle
unplug the 02 sensors from the midpip and remove the midpipe
drain the transmission fluid
remove the shifter (aids in clearance)
remove the drive shaft, you'll need a 12mm 12 pt socket for this. i ended up using a 1/2 drive regular socket with an impact to get the bolts out.
remove the cover over the clutch cable and remove the cable from the fork
disconnect and wiring connections from transmission
support the tail of the transmission with a jack and remove the rear transmission bracket
loosen but do not remove the bolts holding the tranny to the block, now lower the jack to gain access to the top 2 bolts. they are hard to get to but not impossible. I got them from the bottom with a combination of extensions and swivels. I have heard of others going through the tunnel from inside the car now that the shifter is removed.
support tranny near CG with a 2x6 and jack or trans jack if you have access to one.
remove the 7 bolts holding the tranny to the block
slide out transmission
remove old clutch and flywheel, you'll need a puller to get the pilot bearing out.
install new pilot bearing and flywheel, torque spec i believe is 85 lb-ft. don't forget the locktite. install clutch/pressure plate using the alignment tool, i believe the torque spec is only like 20 lb-ft on the pressure plate
remove old throw out bearing and install new, using grease on new bearings and input shaft.
reinstall transmission, might need to cut the "ears" off for more clearance.
refill tranny, bolt up driveshaft, hook up exhaust, reconnect electrical connections
remove old clutch cable and the fork under the clutch pedal and install the aluminum quadrant and firewall adjuster.
reconnect battery
lower car
adjust clutch @ firewall or underneath as necessary.
hope i didn't miss anything, goodluck!
Shawn02GT is offline
mtgldr
02-03-2024 09:00 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Clutch install writeup?
