Rim help
Old Aug 24, 2007 | 06:20 PM
JJ03MustangGT's Avatar
JJ03MustangGT
Default Rim help
can anybody help me. im sellin my rims and trading for 15" pro stars. i need help with the specs. i wantin to do a 295 DR in the back and like a 2xx up front. im thinkin about 15x10 in the back or should i do the 15x8.
will this work: for the back of course
http://store.summitracing.com/partde...p;autoview=sku
Old Aug 24, 2007 | 06:30 PM
JJ03MustangGT
Default RE: Rim help
and whats the lug bolt pattern specs?
Old Aug 24, 2007 | 08:42 PM
8banger's Avatar
8banger
Front can't help ya...unless you go the skinnies route.LOL...I've got 15x10 in back and they look great!!!!..with a 275/50 /15 M/T DR....15x10 with a 6.5 BS on a 4.5 bolt pattern....
Old Aug 24, 2007 | 08:45 PM
8banger's Avatar
8banger
Old Aug 24, 2007 | 11:23 PM
JJ03MustangGT
pm sent
Old Aug 24, 2007 | 11:42 PM
livefast1's Avatar
livefast1
dam son that looks sick
Old Aug 24, 2007 | 11:54 PM
JJ03MustangGT
ok how bout this setup?
front: 15x5/195x75x15
rear:15x10/275x50x15
my car has the eibach pro kit, i also have gears, so i wanna match up as close as i can to the stock tire specs. any help. and if this setup works, how much should i pick up with this?
Old Aug 25, 2007 | 12:27 AM
2000GT4.6's Avatar
2000GT4.6
Don't you all think he would be better off with a 8 inch rim on the back for a 275? My 275s are fitting on a 7 inch rim atm, seems like a 8 would be about right, but a 10 should be streching them a bit on the rim?
Old Aug 25, 2007 | 02:13 AM
doug0122's Avatar
doug0122
what kind of cornering can you expect with 4 to 5 inch rims on the front...im sure nothing insanely fast but ive been told anything over 20 will slide you into a ditch...anyone know about that???
Old Aug 25, 2007 | 08:47 AM
livefast1's Avatar
livefast1
that sounds like an exageration to me im sure there will be some amount of understeer but if you know your riding on sizes that offset you shouldnt be cornering to the limit anyways.
