SUpercharged tune Question
I have a S/C 4.6 and want to increase the boost from 6-12psi. once the car has been tuned for the S/C do you have to retune fot the added boost? The is is running rich right now so what do you think. I'm new to S/C so I'm not sure and don't want to spend money that I don't have too.
RE: SUpercharged tune Question
For sure....you're going to increase power around 21%by doubling the boost. You need to correctly deliver fuel throughout the RPM range to be able to do that. A tune is in your future.
its got about 350 miles on it and as far as a gain went from 190 - 257 rwhp and about 240 rwtq- 307 wrtq. I have to get it retuned for the metanol injection that just came in the mail. The only thing I don't like about the powerdyne is it has a whistle sort of like a jet turbin engine but it goes away after hitting the boost range.
ORIGINAL: sgtbraddick
Its not going to take it unless you have had it gone thru by a aftermarket company, and even then its just not a good idea on a powerdyne. there is a reason they cost half of what a good supercharger does... quailty.
Edit: You will also need a retune definatly.
ORIGINAL: 2000GT4.6
Going to 12 PSI is going to be pushing the limits of your engine, but it won't matter, because if you increase the PSI to 12 on a powerdyne the only thing you are goign to do is constantly shred the belts.
ORIGINAL: nanaki
even then, the cost of the rebuild on powerdynes to be able to take any respectable boost, you'll be spending almost the same money you would have on a non-cooled vortech kit.
ORIGINAL: 2000GT4.6
