P1443 Evaporative Emission Control System Control Valve
Old Aug 25, 2007 | 05:07 PM
impaled's Avatar
impaled
Default P1443 Evaporative Emission Control System Control Valve
P1443 Evaporative Emission Control System. any ideas? it sounds really stupid, but could this have anything to do with my tranny going out because the CEL came on when i was driving home in second at like 40 mph because i had no thrid gear? or is this just some odd coincadence? what would i need to fix to get it to turn off?
Old Aug 25, 2007 | 10:20 PM
impaled's Avatar
impaled
Default RE: P1443 Evaporative Emission Control System Control Valve
anybody?
Old Aug 25, 2007 | 11:54 PM
Chris98Gt's Avatar
Chris98Gt
I have no idea what it is or does but my car throws that code and I don't have tranny problems and the car still runs fine.
Old Aug 26, 2007 | 12:12 AM
livefast1's Avatar
livefast1
try your gas cap
Old Aug 26, 2007 | 07:46 PM
impaled's Avatar
impaled
the gas cap is on tight. any other ideas?
Old Aug 26, 2007 | 08:15 PM
Xemeth's Avatar
Xemeth
It was probably the gas cap. It's very similar to the GM DTC P0445. It's an EVAP thing. It's basically a really fancy way of saying the gas cap was loose. Even if it is tight now, the code has to be cleared before it goes away. Check the pass and fail history to see if it has failed every ignition, or just one a while ago.
Old Aug 26, 2007 | 09:03 PM
Zanador's Avatar
Zanador
Whenever I let my gas get below 1/8th of a tank, without fail I get this code.
No idea why- I just fill my tank and poof it is gone.
Were you low on gas?
8banger's Avatar
8banger
P1443 I believe is a Purge Valve SolenoidFault...Purge solenoid is located under the back of the car next to gas tank..Could be a bad purge valve,voltage to it...leak..
Old Aug 26, 2007 | 10:08 PM
impaled's Avatar
impaled
i was at about 1/8 tank, i will clear the code tomorrow and see if it comes on again and let you guys know. hopefully that is my only problem. thanks.
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
