transmission fluid?
i have a manual 00 gt. does the transmission fluid need to be changed regularly?
how do i check?
I know automatic has a cap that says AT Fluid. does a manual car has one to? where is it located?
Thanks,
how do i check?
Thanks,
If your car is an '00 and has any kind of mileage on it you should change it to be safe.
Mobil 1 synthetic ATF or Royal Purple synchromax are good ones.
http://www.americanmuscle.com/royal-...ion-fluid.html
It is an easy do it yourself job.
ORIGINAL: DTK
how do i check if i have enough fluid?
you know how you check your engine oil level?
is there a lever for transmission fluid?
jwog666
Dec 27, 2021 08:09 PM
Sep 25, 2015 06:42 PM
