Idle problems
Old Aug 30, 2007 | 09:28 PM
arcticman37's Avatar
arcticman37
Default Idle problems
Hey guys looking for a little trouble shooting: When my car is at idle it will drop RPM's extremly low, then begin to knock (shakes the entire car) sometimes it will then just die and sometimes it will shoot back up to around 1500 RPMs and then repeat itself. I know this is very vague but if anyone has any ideas on what my problem could be I would really appreciate it. I do know for a fact that it is not my IAC because I just replaced it about 500 miles ago. My only thoughts were that it could have something to do with my clutch/flywheel/throw-out bearing.
Old Aug 31, 2007 | 01:12 AM
Ehmark's Avatar
Ehmark
Default RE: Idle problems
Sounds like whenI put on my BBK cai,. the idle spot was filled with sand.
Old Aug 31, 2007 | 02:08 AM
Stonewall83's Avatar
Stonewall83
hey man that mustang looks awesome my car has the cobra front clip with the cobra wheels
what kinda wheels do you have???
they look sweet
Old Aug 31, 2007 | 07:50 AM
y2kStangGT's Avatar
y2kStangGT
I had the same problem. changed my IAC valve and the problem was fixed. May be your TB is dirty. Try cleaning it.
BTW, what kind of wheel are those? They look bad azz.
do you have a close up pic of the wheels?
Thanks,
Old Aug 31, 2007 | 07:57 AM
jmac72187's Avatar
jmac72187
corner carver
I had the same problem. My PCM was bad.
Old Aug 31, 2007 | 12:06 PM
SikSide00GT's Avatar
SikSide00GT
Sorry but wahts a PCM?? and Articman i kinda have the same problem my car will drop a couple hunred RPMS at idle like down to 450 at the lowest and the car feels like its shaking. but it only does it once in a while... any suggestions?
Old Aug 31, 2007 | 01:15 PM
Murdoc's Avatar
Murdoc
I ♥ Acer
IAC or TP sensor. be careful if you clean your tb... im not sure what year mustangs, but cleaning your tb can screw it up.
Old Aug 31, 2007 | 02:14 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: SikSide00GT
PCM = Powertrain Control Module
Basically the computer in your car.
Old Aug 31, 2007 | 02:18 PM
SikSide00GT
Jesus!!!! how much did that cost
Old Aug 31, 2007 | 03:06 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
i heard you shouldnt clean your throttle body cause it has afilm on the inside designed to catch crap. i didnt know this and cleaned mine whenever i see that its dirty. A PCM not under warranty can run upwards of a thousand bucks, depending on the stealership
