installing a pushrod and away with the modular
I would love to throw my modular engine in the garbage and put in a 5.0L like the 94-95gt's. I know it can be done, but I need my car to pass Federal emissions and the cut-off is 96+ because of the OBDII. What can I do make this work properly and pass emissions test when I get inspected? Did Ford make a 5.0L after 1996 where I could use that computer? Thanks
Because the 4.6L mod motors are a pain to work with and very expensive at that. They cost an arm and a leg for little hp increase! You can spend $1200 on a 5.0 with a head swap and pick up 60hp. Try doing that on a mod motor! You need a whole lot of stuff or a s/c'er to get those numbers. Also a headswap on 5.0L motors don't have that stupid idea of a timing cover to get them off either.
Depending on how crazy your inspection is - if the inspector can verify the engine you installed came out of an older car- it'll fail. But I highly doubt you'd run into that problem.
It's going to take some work to get a 302 in your car, probablyin the same ballpark as itwould be for forged internals & bumping your 100shot to a 200.
Sep 10, 2015 08:39 PM
Hang in there is will be worth it when it's all done
